TwinTurbo.NET: Nissan 300ZX forum - Re: Re: 20lbs of boost/110 octane race fuel Kumho tires
M:a-2
on September 16, 2002 at 4:22 PM
Re: 20lbs of boost/110 octane race fuel Kumho tires (n/m)
posted by M:a-2
on September 16, 2002 at 04:21 PM
Run a good pr of slicks and your 60' will drop below 2sec. and your qtr should improve by .4 to .5 secs.
Just got back fromt the dragstip
cassi8u99
14:54:16 09/16/02
That's it !! you have a stage V+ !!
PLEAZURE in CA (SD)
15:03:29 09/16/02
Having a hard time launching the beast....
cassi8u99
15:12:44 09/16/02
every 100 lbs = -.1 sec so if you dump it your running 12.8
Halo Z
15:15:36 09/16/02
If i pedal the clutch it smokes!
cassi8u99
15:18:38 09/16/02
pedal from 5k? yeah i would think so. try 3k. (n/m)
Halo Z
15:20:23 09/16/02
Like i said it would smoke!
cassi8u99
15:29:29 09/16/02
GEt an RPS MAX (6-puck sprung hub). I've dropped it at
boileralum00
21:24:15 09/16/02
Did you make the sub box out of lead? (n/m)
blaZe(Dallas)
16:42:34 09/16/02
i see 4+ either way he should be in the 12 like you said (n/m)
Halo Z
15:13:03 09/16/02
how much boost? (n/m)
Jefe
15:35:17 09/16/02
Re: Just got back fromt the dragstip
M:a-2
15:37:21 09/16/02
cassi8u99
15:46:39 09/16/02
M:a-2
16:21:12 09/16/02
Re: Re: 20lbs of boost/110 octane race fuel Kumho tires -
M:a-2
16:22:39 09/16/02
20 psi on STOCK turbos?
stupidfast
18:43:35 09/16/02
Drag strip = short burst of power, not WOT
Chip(GinnMotorsports)
22:45:14 09/16/02
Not the turbo's being killed here, injectors are maxed! :) (n/m)
ZBlacktt
23:16:31 09/16/02
with 110 octane, not long enough to hurt anything.
11:31:31 09/17/02
